OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
OS-V: 0100 Membrane with Hot-Spot Test No. T1OptiStruct examines the direct stress in y direction at a point D outside the hot-spot for linear thermos elastic analysis.
