Output Data
The file names in this section contain only the tail part of the name. For most files, the full file name is controlled by the OUTFILE command (ASSIGN,OUTFILE), and in the absence of OUTFILE, they use the root of input file name. Unless otherwise noted for a specific file type (.#.eigv), all output files have the same root and are located in the same folder. The only exception is <BODY_NAME>.h3d; these files may not have a common root in the file name.
