/DESOBJ
Optimization Keyword This keyword can be used to select a response as the objective function of an optimization run by selecting a response as the objective function. The selected response can either be minimized or maximized based on the inputs specified on this keyword.
| /DESOBJ | |||||||||
| title | |||||||||
| type | resp_ID | ||||||||
Definition
| title | Title. (Character, maximum 100 characters) |
| type | Optimization type.
No default (Integer) |
| resp_ID | Optimization response
identifier defined on /DRESP1 card.
This field is used to select a response as the objective of an
optimization run. No default (Integer > 0) |
- Only one objective can be defined for an optimization run. Therefore, multiple /DESOBJ entries are not allowed in a single solver deck.
- This entry is represented as an optimization objective in HyperMesh and HyperCrash.
