Groups(Sets)
| Groups | Keywords | Group Selection |
| Element/Part | /GRBEAM | Beam elements |
| /GRBRIC | Brick elements | |
| /GRNOD | Nodes | |
| /GRPART | Parts | |
| /GRQUAD | Quad elements | |
| /GRSH3N | 3-node shell elements | |
| /GRSHEL | 4-node shell elements | |
| /GRSPRI | Spring elements | |
| /GRTRIA | 3-node solid elements | |
| /GRTRUS | Truss elements | |
| Boxes | /BOX/BOX | Box(es) |
| /BOX/CYLIN | Cylinder type of box | |
| /BOX/RECTA | Rectangle type of box | |
| /BOX/SPHER | Sphere type of box | |
| Lines | /LINE/BOX or /LINE/BOX2 | Lines which selected with box |
| /LINE/EDGE | Lines which selected with edges of the surfaces. | |
| /LINE/GRBEAM | Lines which selected with group of beams. | |
| /LINE/GRSPRI | Lines which selected with group of springs. | |
| /LINE/GRTRUS | Lines which selected with group of trusses. | |
| /LINE/LINE | Lines which selected with lines. | |
| /LINE/MAT | Lines which selected with material. | |
| /LINE/PART | Lines which selected with part. | |
| /LINE/PROP | Lines which selected with property set. | |
| /LINE/SEG | Lines which selected with segments. | |
| /LINE/SUBMODEL | Lines which selected with submodel. | |
| /LINE/SUBSET | Lines which selected with subset. | |
| /LINE/SURF | Lines which selected with surface. | |
| Surfaces | /SURF/SEG | Surfaces which selected with segments. |
| /SURF/SUBSET | Surfaces which selected with shell subsets. | |
| /SURF/SUBMODEL | Surfaces which selected with submodel. | |
| /SURF/PART | Surfaces which selected with shell parts. | |
| /SURF/ELLIPS | Surfaces which selected with group of 3D elements. | |
| /SURF/GRSHEL | Surfaces which selected with group of shells. | |
| /SURF/GRSH3N | Surfaces which selected with group of 3-node shells. | |
| /SURF/MAT | Surfaces which selected with shell material. | |
| /SURF/PROP | Surfaces which selected with shell property. | |
| /SURF/SURF or /SURF/DSURF | Surfaces which selected with surfaces. | |
| /SURF/BOX or /SURF/BOX2 | Surfaces which selected with box. | |
| Surfaces (geometry) | /SURF/ELLIPS | Surfaces which selected with hyper-ellipsoid geometry. |
| /SURF/MDELLIPS (Obsolete) | Surfaces which selected with Madymo ellipsoid. | |
| /SURF/PLANE | Surfaces which selected with infinite plane. |
