Tutorial: Polymer Coextrusion
Set up and run a coextrusion analysis.
Open the Tutorial Model
Orient the Model
Extract Flow Volume
Delete Unwanted Solids
Select Materials
- EXXON_PAXON_AB50_003
- HF_PC_LEXAN_GE
Specify Process Data: Inlets
Click the Inlet icon.
Zoom in to the first Inlet Region of the Polymer Melt.
Select the first inlet face. Specify the inlet conditions:
Zoom in to the second Inlet Region of the Polymer Melt.
Select the second Inlet face. Specify the inlet conditions:
Organize Solids Into Polymer Layers
Cut Land
Create Profile Solids
Save Model
Submit the Job for Simulation
Click the Analysis icon.
Specify the parameters of the analysis process.
- Click Run.
Monitor Job Status
View Simulation Results
