Verify Netlist
Use Verify Netlist to compare PCB design and net list files that are used in the manufacturing process (*.fpn and *.net).
- FPN Path: The FPN file is exported from the Bare Board Tester (BBT) with the pin number and the pin name.
- Net Path: The NET file is exported from the BBT with the net name and the pin number.
| Term | Description |
| PCB | Net name in PCB design. |
| JIG | Net name in imported netlists. |
| ALL | Number of extracted JIG (Test Point) data. |
| PCB | Number of connected pins in PCB design. |
| JIG | Number of connected pins in imported netlists. |
| D-PCB | Number of connected pins only in PCB design excluding the connected pins in the net on both PCB design and netlists. |
| D-JIG | Number of connected pins only in netlist, excluding the connected pins in the net on both PCB design and netlists. |
