Altium Designer
- Extract Altium Designer ASCII file, *.PcbDoc, in Altium Designer.
From the menu bar, click File > Import ECAD > Altium Designer.
The Import from Altium Designer dialog opens.
- Layer Set-Up: Set Altium layers’ name which will be used as PDB’s component outline layer, board outline layer and Drill Layer.
- Use 0 for COC line width: Apply the line width of COC to zero.
- Define Part Name: You can set the ECAD Part name as a Property or Parameters value.
- Property Keyword Name: Set the Part Name with the Design Item ID or Footprint Name in Altium Designer design data.
- Parameters Name: Set the ECAD Part Name with the parameter of Altium Designer design data you specified.
- Apply to Environment Setting: Apply settings to the environment setting.
Select the target ASCII file, *.PcbDoc, to import.
The format to import Altium Designer is shown in Figure 1. Example of *.PcbDoc.Figure 1.Note: In Altium Designer, you can save a file either binary or ASCII format with the same extension (*.PcbDoc). You should import the ASCII format data into PollEx.
