Logic DFE
PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
PollEx Logic DFE is an option module of PollEx Logic and it helps designers to reduce recursive design errors that might be detected in post design processes. A well-arranged schematic design result is a good quality PCB. Correctly chosen net names make PCB designers easily route the board. PollEx Logic DFE also allows you to set standard net naming convention. The results of PollEx Logic DFE can be exported into a well-formatted MS/Excel spreadsheet. With a variety of user-friendly electrical rule checking options, PollEx Logic DFE helps you to reduce time and cost to produce better working PCBs faster.
