Slice a set of solid objects with a cutting plane or surfaces.
                On the Geometry ribbon, select the
                        Slice tool.
                    Note: The tool may be hidden in the dropdown menu. To
                        access the dropdown menu, you can do one of the following:
                            - Select  at the lower right corner of the
                                currently displayed tool. at the lower right corner of the
- Click and hold the currently displayed tool.
                In the guide bar, click  for more Options: for more Options:
                        - Extend Surface: Extend the surface to completely
                            cut the target.
- Optional:
                By default, the targets are assumed based on where you position the cutting
                    plane or surfaces. To select your own targets, click Targets on the guide bar, and then select one or more
                    parts.
                Do one of the following:
                        - Click Plane on the guide bar, and then
                            click on the part to define the cutting plane.Note: As you mouse over the target, a red circular
                                saw appears to indicate where the cutting plane will be positioned.
                                Hovering over an edge gives a perpendicular cutting plane, while
                                hovering over a face produces a planar cutting plane.
- Click Surfaces on the guide bar, and then select
                            one or more surfaces that intersect the target part.Tip: To toggle between selecting Targets
                                or Surfaces, right-click or press
                            Tab.
                Click Apply
                     on the guide bar or microdialog. on the guide bar or microdialog.
All individual solids are placed into separate parts.Tip:
                    - To reposition the cutting plane using the Move tool,
                        click  . .
- To align the cut plane to the x-, y-, or z-axis, click  . .
