Use the Object Inspector or context menu to rename objects in your user interface
design.
All objects that you include in your user interface design are listed by name in
the Object Inspector. Choosing meaningful names can help you organize and manage objects
as you develop your design. The object names are reflected in the code when you save
your design as file.
Review the objects in your design.
Note: The object names are not
to be confused with text that can be used as a label such as "Fast" and
"Detailed" that you see in the example Dialog. Text is an object itself and
is listed in the Object Inspector.
Change an object name with the following options:
Note: Spaces and special characters are not allowed in
object names.
The example shows the name change for the Slider object from
Slider
to
AnalysisType
Name changes are
also reflected in the code when the design is saved as file.
