break
The break keyword immediately terminates a for or while loop.
for j = 1:10
disp(j)
if j == 3
break
end
end
1
2
3
Discover new features and enhancements.
New to Twin Activate? Learn the basics here.
Start using Twin Activate with our interactive tutorials.
Learn about the features and functionality available in Twin Activate.
Explore the Extended Definitions, OML Guides, Block Library, API Guide and Glossary.
PDF file with in-depth information on key topics in the User's Guide.
OpenMatrix is a mathematical scripting language.
Literals are items that are constant throughout the life of the application. Literals include numeric, imaginary, characters, strings, logicals, and Other (NaN/Inf).
Data types are items that are constant throughout the life of the application and are built into the OpenMatrix language.
Strings are arrays of characters.
OML language scripts manipulate data through variables. Variables are referred to by their name (alphanumeric) and can be created (assigned) and deleted as described in this section.
Indexing is used to retrieve one or more specific values out of a collection.
Operators are used to combine operands.
Each operator in this section is explained with the operations of scalars, vectors, and matrices that are allowed for said operator.
Statements are made of expressions, which may be simple or complex.
Loops are used to perform the same set of statements multiple times.
Loops are used to perform the same set of statements multiple times. The for loop runs the statements a set number of times based on the number of elements in the collection found on the first line of the for loop.
Parfor loops behave similarly to regular for loops except that they attempt to use multiple processors or threads to divide the loop space into chunks. The chunks are equally-sized (or as equal as possible).
Loops are used to perform the same set of statements multiple times. The while loop runs the statement until a condition is no longer met.
OpenMatrix language supports conditional execution of statements using the if/elseif/else construct.
OpenMatrix Language also supports a variant of this using switch/case/otherwise.
The try /catch block allows you to stop errors from being returned, and allows another block of code to execute instead of the error.
There are two types of workspaces: Local and Global.
Functions are packets of statements that can be used repeatedly.
OpenMatrix statements persist in .oml files.
This section describes files that can be manipulated by the OpenMatrix Language.
Errors and warning messages are both output in the console (or the Command Window in GUI mode) of Twin Activate.
Create 2D and 3D plots and control their style and appearance.
Objects in OML are defined using the classdef keyword. This creates a blueprint for an object but does not actually create (instantiate) anything.
The Reference Guide contains documentation for all functions supported in the OpenMatrix language.
Describes all of the blocks in the installed Twin Activate library.
Provides information about developing and simulating models through the Twin Activate Application Program Interface.
Key terms associated with the software.
You've got questions? We've got answers!
ON THIS PAGE
for j = 1:10
disp(j)
if j == 3
break
end
end
1
2
3
ON THIS PAGE
