Recursion
The function body can include calls to other functions and calls to itself. This is referred to as recursion.
function b=factorial(a)
if a==1
b=1
else
b=factorial(a-1)*a
end
end
Discover new features and enhancements.
New to Twin Activate? Learn the basics here.
Start using Twin Activate with our interactive tutorials.
Learn about the features and functionality available in Twin Activate.
Explore the Extended Definitions, OML Guides, Block Library, API Guide and Glossary.
PDF file with in-depth information on key topics in the User's Guide.
OpenMatrix is a mathematical scripting language.
Literals are items that are constant throughout the life of the application. Literals include numeric, imaginary, characters, strings, logicals, and Other (NaN/Inf).
Data types are items that are constant throughout the life of the application and are built into the OpenMatrix language.
Strings are arrays of characters.
OML language scripts manipulate data through variables. Variables are referred to by their name (alphanumeric) and can be created (assigned) and deleted as described in this section.
Indexing is used to retrieve one or more specific values out of a collection.
Operators are used to combine operands.
Each operator in this section is explained with the operations of scalars, vectors, and matrices that are allowed for said operator.
Statements are made of expressions, which may be simple or complex.
Loops are used to perform the same set of statements multiple times.
There are two types of workspaces: Local and Global.
Functions are packets of statements that can be used repeatedly.
Anonymous functions can be defined anywhere inside a script.
Use the clear command (passing the function name as an argument) to clear (delete) a function from the session and make it inaccessible.
Eval is a special function that accepts a string that is itself an OML script. The function evaluates the script and returns the appropriate value.
Functions are packets of statements that can be used repeatedly. They can accept any number of inputs and can return any number of outputs.
Define functions using the function keyword.
If a function is defined in its own file, the function name must match the file name.
There are two special identifiers, nargin and nargout, that indicate the number of parameters passed into and the number of parameters returned from the function respectively.
Nested functions are functions within the main function.
Function arguments are passed by values in OpenMatrix language functions calls.
Return is a special keyword that is only available in functions. It immediately ends the function.
Functions can be written to accept or return an indefinite (or 'variable') number of arguments. To do so, use the varargin and varargout variables.
OpenMatrix statements persist in .oml files.
This section describes files that can be manipulated by the OpenMatrix Language.
Errors and warning messages are both output in the console (or the Command Window in GUI mode) of Twin Activate.
Create 2D and 3D plots and control their style and appearance.
Objects in OML are defined using the classdef keyword. This creates a blueprint for an object but does not actually create (instantiate) anything.
The Reference Guide contains documentation for all functions supported in the OpenMatrix language.
Describes all of the blocks in the installed Twin Activate library.
Provides information about developing and simulating models through the Twin Activate Application Program Interface.
Key terms associated with the software.
You've got questions? We've got answers!
ON THIS PAGE
if a==1
b=1
else
b=factorial(a-1)*a
end
end
ON THIS PAGE
