Warning Messages
Warning messages are similar to error messages in that they are output into the console or command window.
However, on a warning, a script or function will continue its execution while it stops on error.
Warnings are used when a command cannot be performed or in some computations (for example, if a matrix is almost singular).
Although this can be changed, error messages are outputted in red, while warnings are outputted in black.
warning('this is a warning')Warning: this is a warningrmpath('E:/MYPATH')
Warning: 'E:/MYPATH'is not in path in the call to the function rmpath on line 1.
