Define this block with C commands and functions.
The CCustomBlock provides a generic interface for specifying the block's properties
and defining its simulation function based on C commands and functions. The simulation
function is specified in C code and stored as a block parameter. The C code is used
during simulation.
From the Palette Browser, select . Drag and drop the block into your diagram and double-click
it.
The block dialog appears with tabs to define the Ports, States,
Parameters, SimFunction and other advanced properties for the
block.
On the Ports tab, enter the number of input and output
ports for the block, enter a name for each port, then click OK.
On the States tab, enter the state of the block with
respect to its initial continuous condition, initial state derivative, initial
discrete state, and number of initial object states, then click
OK.
On the Parameters tab, enter the number of parameters
for the block. For each parameter, enter a name, value, and type, then click
OK.
On the SimFunction tab, generate a code skeleton, enter
the simulation function for your block, then click OK. The skeleton provides the essential
framework for the C function that interfaces with inputs, outputs and events.
Additional options:
On the Advanced tab, enter the number of modes and
zero-crossings for the block, select the activation mode: always
active, initially active or
standard, then click OK.
