FMU and MotionSolve
How do I avoid using an absolute file path with FMU and MotionSolve blocks?
Use a relative path
FMU and MotionSolve blocks, as well as other blocks that require file inputs, support the use of a relative path, meaning that the input file is always relative to the current model .scm file.
How do I avoid using an absolute file path in a Twin Activate context to a local file?
In the model initialization or model context, obtain the current model directory with this command:
d = fileparts(bdeGetCurrentModelFilePath)
For example, if the model is located here: C:/work/model1.scm, the above command stores C:/work in the d variable.
