Optimization and Linearization
Learn about the methods to optimize and linearize models.
Optimization
Perform optimization studies in Twin Activate through the Optimization Editor or BobyqaOpt block.
Optimization Editor
From the Optimization Editor, you can define cost and constraint functions and parameters, and generate and run a reusable OML script for a given optimization problem. You can also use the OML scripting features to run simulations in batch mode.
From Twin Activate, select Tools > Optimization Editor.
BobyqaOpt Block
The interface of the BobyqaOpt block lets you define parameters to optimize your model. From the Palette Browser, select Activate > Optimization > BobyqaOpt.
For examples and information about the BobyqaOpt block, see the Extended Definitions for Advanced Users.
