Run in Batch Mode
The batch mode option is especially useful for process automation, optimization, and other repetitive simulation tasks.
Run in Batch Mode on Windows
Run in Batch Mode on Linux
Batch Mode Start Options
| Option | Argument | Required or Optional | Description | Platform Support |
| -i | <space separated inputs> | Optional | Passes input(s) to scripts. These options can be accessed in
Twin Activate by the OML commands: getcmdinput and
getnumofcmdinputs. To pass cell arrays or
matrices on Linux, the open/close braces and semi-colons need to be
quoted.Linux
example:
Windows example:
All supported platforms. |
| -f | <filename>.<extension> | Required |
