Introduction
The main inputs of this test correspond to a set of losses to be considered for evaluating the thermal behavior of the machine in a transient mode.
Standard inputs
Speed
The speed of the machine is to be considered.
Set of losses
- Stator Joule losses
- Stator iron losses
- Magnet losses
- Rotor iron losses
- Mechanical losses
Maximum allowed deviation
The maximum temperature deviation allowed to consider the optimization algorithm has converged. All the final temperatures must have a lower deviation.
Input import
Please, refer to the section "Input import".
Advanced inputs
There are no advanced inputs required for this test.
