Via-Trace Crosstalk
Inductive coupling is null to zero due to the perpendicular current flows on via and trace.
View new features for PollEx 2023.1.
Discover PollEx functionality with interactive tutorials.
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
Group the same type of objects into the same group.
This item reports problems when low frequency power and high frequency signal traces are routed too close to each other.
This item checks whether high speed signal vias have their ground vias as shielding within a certain region.
This item checks for high speed signal’s inner via structure.
This item checks for a shielding ratio on design. Ground shielding should consider the effect on impedance change.
To get a stable high signal transmission, plane as return path should be on adjacent layers.
High speed signals are very sensitive for outside noise, it is better to make shielding with ground. In case of high-speed signal flows over split ground plane, the shielding effect would be reduced.
Component providers can guide their products’ signal connection specification as topology style, impedance or delay time control.
View DFE Environment setting methods.
PollEx DFE+ is a fully automated SI analysis tool.
PollEx DFM is a board level manufacturability checking software.
PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
PollEx Technical Cleanliness (TC) is an optional module of the PollEx PCB and a reliability analysis tool set for hazardous areas on a PCB design, using its micro particles.
This section contains the PollEx UPE user guide.
Instruction to install PollEx 2023.1.
Definition for meta character using in making sentence for searching option.
