Tutorial: High Pressure Die Casting
Set up a high pressure die casting simulation and see how to troubleshoot it.
In this exercise, you will learn how to run an analysis and prevent typical casting defects for the high pressure die casting process. The process must balance the need to fill the mold quickly enough to prevent premature solidification with the need to fill the mold slowly enough to prevent air mixing with the liquid, causing porosity in the finished part.
Model file is available in the tutorial_models folder in the installation directory in Program Files\Altair\2023.1\InspireCast2023.1\tutorial_models\handle.x_b.
Import Geometry
Designate a Cast Part
Create an Ingate
Create a Mold
Configure Basic Setup
Run Analysis
Run the Temperature Animation
View the Porosity Result
- To avoid defects like trapped air, we can optimize the size, shape, and placement of the inlet. Experiment with the gate's configuration and placement and re-run the analysis to see the difference in the results.
- Once you know the optimal configuration of the inlet, you can design a filling system for high-pressure casting.
Open the New Model
Use the model provided to run a high-pressure casting analysis.
- Click File>Open.
- Browse to and select <installation directory>\tutorial_models\handlefull.x_b
Cast Material and Temperature
Designate Filling System
Set Gravity Direction
Generate a Mold
Generate a Shot Sleeve
Configure High Pressure Parameters
Run Analysis
Run the Flow Front Animation
View Last Air Result
to select the
