Recommendations for Flux 2D
As seen previously, this document aims to determine the best combination between the number of cores used and the choice of the solver to save as much time and memory as possible during solving.
For Flux 2D, we use the two machines below by varying the mesh to increase the number of nodes in order to, recommend the right solver and the right number of cores according to the number of mesh nodes.
Figure 1. Both machines used by Flux 2D for the recommendations
Machine (a) is used for Magnetostatic and Transient Magnetic applications; it is a three-phase permanent magnet synchronous machine with 8 poles. In Magneto-Transient, the magnets are considered as solid conductors, and the machine is fed by a circuit coupling.
Machine (b) is used in Steady-State AC magnetic application, it is an induction machine with 2 poles also powered by a circuit coupling.
Several simulations are therefore launched with a different mesh (from the coarsest to the finest) with each time a number of cores and a different solver in order to draw up a table recommending the best choices.
Figure 2. Evolution of the mesh in a rotor slot of the induction machine with (a) a coarse mesh and (b) a fine mesh
Several recommendations are provided in the tables below for each of the Flux 2D applications (Transient Magnetic, Steady-State AC magnetic, and Magnetostatic):
| Magnetostatic project | ||||
| Number of nodes in the mesh | 0 - 100k | 100k - 600k | 600k - 1.5M | 1.5M + |
| Recommended number of cores | 1 | 2 | 4 | 4 to 8 |
| Minimal memory required | 1 GB | 2 GB | 4 GB | 6+ GB |
| Recommended linear solver | Direct (MUMPS) | |||
| Steady-State AC magnetic project | |||||
| Number of nodes in the mesh | 0 - 200k | 200k - 500k | 500k - 1.5M | 1.5M - 5M | 5M + |
| Recommended number of cores | 1 | 2 | 4 | 8 | |
| Minimal memory required | 1 GB | 2 GB | 4 GB | 12 GB | 16+ GB |
| Recommended linear solver | Direct (MUMPS) | ||||
| Transient Magnetic Project | ||||
| Number of nodes in the mesh | 0 - 100k | 100k - 400k | 400k - 1.5M | 1.5M + |
| Minimal memory required | 500 MB | 1 GB | 2 GB | 4+ GB |
