New GUI and user guide for coil modeling
Modification of the GUI of coil conductor region to be easier friendly.
Introduction
- the Coil conductor region and
 - the Coil conductor region with losses (available only in AC Steady State Magnetic application)
The backward compatibility of all legacy Flux projects and of all related Python commands is ensured. However, a few types of wire belonging to the coil conductor region with losses that were redundant were not converted to the new Coil conductor region. These are no longer available for creating new regions, but they are still usable (even for new computations) in read-only mode by users loading legacy projects. In case the user needs to modify the definition of such a region, he or she is encouraged to move forward to the new scheme, which is intended to be more friendly and simple. All details on these changes are presented below. Several messages and warnings are also displayed by Flux to support the user in this transition.
- Presentation of the new GUI;
 - Backward compatibilities;
 - New enhanced section of Flux user guide on coils and windings.
The new GUI for the coil conductor region includes now two tabs ensuring the input of all the parameters leading to a fully described coil. The content of these two tabs is detailed in the following paragraphs.
The first tab labeled as "Basic Definition" allows the user to describe the essential parameters of the coil conductor region, such as the orientation of the current, the associated circuit component and the number of turns. It also contains settings related to the management of the symmetries and the periodicities, as shown in Figure 1(a). If the user fills only the fields of this tab, Flux will simulate an ideal coil without losses and any loss-related quantity on the region will not be available for post-processing.
- Simplified description (neglects proximity and skin effects)
 - Detailed description (considers proximity and skin effects), available only in AC Steady State Magnetic application
The simplified description shown in Figure 1(b) allows the computation of the Joule losses in the region without taking into account the proximity and skin effects, that may be important at higher frequencies. This simplified definition only asks for the fill factor coefficient of the coil.
On the other hand, the detailed description presented in Figure 1(c) considers the proximity and the skin effects in the Joule losses computation through special homogenization techniques. Consequently, to set up this model, Flux asks for a full description of the coil wires, i.e., it requires more geometric parameters. Several possibilities (or unit cell templates) exist in this case, as described in Table 1 below:
| Type | Required parameters |
| Rectangular section wire |
| Circular section wire: diameter |
| Circular section wire: fill factor |
Backward compatibility
According to the previous section, the definition of a Coil conductor region in the dialog box is now split in two parts: the electrical definition of the coil is done in a first tab called Basic Definition (Figure 1(a)), while the definition of a Joule losses model (requiring the coil material and the coil fill factor) is now performed in the Coil loss models tab by selecting the Simplified description (Figure 1(b)).
For legacy regions created with older versions of the software, Flux 2021.1 ensures backward compatibility. The fields in the dialog box are automatically updated while opening a project created with a previous version and the old Python commands are still valid in user scripts and macros based upon them.
- The legacy Coil conductor region does not have neither the material nor the fill factor defined: in this case, only the Basic Definition tab will be automatically filled in the new GUI.
 - The legacy Coil conductor region has a material or the fill factor value: in this case, only the tab Basic Definition will be automatically filled in the new GUI. In fact, both parameters are mandatory for the simplified description and Flux can't perform an automatic conversion without one of them.
 - The legacy Coil conductor region has the material and the fill factor defined: in this case, both tabs Basic Definition and Coil loss models with simplified geometrical description will be automatically filled in the new GUI.
- Rectangular section: dimensions and gaps
 - Circular section: diameter and gap
 - Circular section: fill factor and number of strands
 - Circular section: diameter and number of strands
- Rectangular section: dimensions and gaps: this model is now in read-only mode; the region remains valid even for new computations: the number of turns (which was not a mandatory parameter) is automatically evaluated during solving. An automatic conversion to the corresponding region in the new GUI Rectangular section wire was not feasible due to redundant parameters in the legacy way of definition: this region now asks for one quantity (the ratio between horizontal and vertical gaps) instead of two quantities (the value of the horizontal and the vertical gaps).
 - Circular section: diameter and gap: this model is now in read-only mode; the region remains valid even for new computations: the number of turns (which was not a mandatory parameter) is automatically evaluated during solving, but there is no corresponding region in the new GUI since this legacy way of definition was redundant with the option Circular section: diameter and number of strands.
 - Circular section: fill factor and number of strands: this feature remains fully available in the new GUI: its corresponding template is the Circular section wire: fill factor and the legacy projects are automatically converted. In this region, the number of strands asked in the previous version is now computed by multiplying the number of turns and the number of strands in parallel.
 - Circular section: diameter and number of strands: this feature remains fully available in the new GUI: its corresponding region is the Circular section wire: diameter and the legacy projects are automatically converted. In this region, the number of strands asked in the previous version is now computed by multiplying the number of turns and the number of strands in parallel.
A new documentation branch describing the creation and usage of coil entities is now available in the user guide. Since coils are frequently present in Flux projects, these new chapters aim to discuss their representation from a user-oriented point of view.
This section discusses the new GUI presented in the previous paragraphs of this release note. Moreover, it goes further beyond describing other region types (solid conductor region) and entities (non-meshed coil magnetic sources) allowing the representation of windings in Flux projects.
This new documentation is composed of the following topics:
- a general overview;
 - several topics describing all possible regions (coil conductor and solid conductor regions) allowing the modeling of windings, including examples of application.
 - a topic discussing non-meshed coil entities;
 - a chapter on the use of symmetries and periodicities with coils;
 - a summary of the availability of the different coil models in Flux applications;
 - bibliographical references.
This documentation node is accessible in the Flux user guide through the following path: Flux > Construction of a Flux project > Coils and winding and/or by typing Coils and windings in the dedicated search engine of the Flux user guide.
