Magnet (unidirectional): spline demagnetization curve
Presentation
This model ( Nonlinear magnet described by a spline ) defines a magnet with a nonlinear B(H) characteristic starting from experimental B, H values.
The definition of the B(H) behavior law with this model is a little longer than with the analytic models, but the experimental curve is modeled more accurately.
Main characteristics:
- the mathematical model and the direction of magnetization are dissociated
 - a single material for description of several regions
Mathematical model
In the direction of magnetization the model is constructed in the following manner:
- entry of experimental B, H values
 - interpolation by a spline function
In transversal directions , one can write:
B⊥(H)= μ0μr⊥H⊥
where μr⊥ is the transverse relative permeability
