Imported Data Collection
- The geometries of both projects must be the same.
To perform the import of data from another Flux project, in the Definition tab, the user is invited to:
- Set the Project name where the data were exported;
 - Set the Data Export Name to import (the same name as in the project where the data export has been created);
 - The associated mechanical set if there is a mechanical set;
 - Choose the collection interval:
- Collect for all the steps of the scenario;
 - Collect only for the current step;
 - Collect for a specified interval;
- Select the spatial quantity to map;
 - Select the list of face regions where the mapping must be achieved;
 - Select the method to apply for the out-of-domain nodes:
- Closest neighbors;
 - Setted to 0;
 - Defined by a space formula;
This data import does not import a file but an object stored in the Flux database of the project that is generated into another Flux project with the Export data to Flux.
