Extrude lines / Extrude faces
Before starting
It is necessary to have a transformation (created beforehand) and lines / faces to be able to extrude points.
Extrude lines / faces
To extrude lines / faces:
| Step | Action |
| 1 |
                         Select the lines / faces to extrude:
| 2 |
                         Activate the command *:
| → | A new dialogue box is opened. |
| 3 |
                         Fill out the fields:
| 4 |
                         Validate the information:
| → | The new entities created (points, lines, faces, volumes) depend on the selected option. |
| → | A new dialog box for the extrusion of entities of the same type is automatically opened. |
| 5 |
                         Quit the sequence:
