Options of construction by extrusion
Building options
Some building options are proposed in order to simplify the user's work and to carry out semi-automatically a certain number of repetitive tasks.
These options, classified in two categories, are presented in the table below:
| The options … | allow … |
| for geometric building |
| for mesh preparation |
Shape of the connection elements
In many cases, the user wishes to have connection elements whose shape depends on the transformation applied (segments for a translation, arcs of circle for a rotation). But in certain particular cases he can wish to apply other rules.
Two extrusion types are proposed and presented below:
- standard type, where the shape of the connection elements depends on the type of transformation (see the table below)
| The type of transformation is a … | the connection elements are … |
| translation | segments |
| rotation | arcs of circle |
| affinity | segments |
| helix | arcs of circle |
- straight forced type, where the connection elements are obligatorily segments
Example of extrusion
The two extrusion types, standard and straight forced, are presented below, line extrusion with a transformation (rotation with 30° around a pivot point P).
                         Standard type (connection elements = arcs of circle)  |
                         Straight Forced type (connection elements = segments)  |
Options for geometric building
The options for geometric building allow to define the geometric entities (points, lines, faces, volumes) created during the extrusion.
These options are presented in the table below:
| Action | Available options | |
| Add points, lines | Add points, lines, faces | |
| Extrude Lines |
| Add points, lines | Add points, lines, faces, volumes | |
| Extrude Faces | ||
Option for mesh preparation
Simultaneously with the creation of faces and/or volumes the option for mesh preparation allows:
- to automatically create the extrusion mesh generator associated with the transformation used for extrusion
 - and to assign this extrusion mesh generator to the faces / volumes created
This option is presented in the table below:
| Action | Available options | Name of mesh generator (automatically assigned) | |
| Creation of … | and assignment of … | ||
| Extrude Lines | extrusive mesh generator associated to transformation | mesh generator to created faces |
                         EXTRUSIVE_NAMETRANSF  |
| Extrude Faces | extrusive mesh generator associated to transformation | mesh generator to created volumes | |
Where NAMETRANSF is the name of the transformation.
For more information on extrusive mesh generator refer to chapter Mesh: software aspects.
