Global quantities (electrical component) available in Magneto Static
Usual global quantities (Component)
The usual global quantities available for a computation on an electrical component in magneto static are presented in the table below.
                         Usual global quantities (Electric component) in MS  |
                         Flux Name  |
                     Flux Unit | Application | |||
| 2D plane | 2D axi | 3D | ||||
| Coil conductor | Flux (magnitude) | FluxCoil | Wb |
Global quantities « advanced » (Component)
The global quantities (advanced used) available for a computation on an electrical component in magneto static are presented in the table below.
                         Global quantities “advanced use” (Electric component) in MS  |
                     Name and formula |
                         Electrical potential on the terminal of a circuit point CP  |
                     V(CP) |
                         Difference of potential between two circuit points CP1 and CP2  |
                     V(CP1) – V(CP2) |
