Switch and Diode: definition (structure)
Definition
A switch and diode components are defined by:
- a name (and a comment)
 - a model
 - specific characteristics depending on the model
 - a command
 - two terminals
Name
The name permitting the identification of the component is given by the user when this is created by him.
A comment (optional) can be added to the name.
The name and the comment are displayed by default in the graphic zone close to the symbol.
Switch and Diode: description
Characteristic quantities, necessary for the description of the switch and diode components are presented in the table below.
| Components considered | Proposed models and their characteristics | |
                         Switch Diode  |
                         Roff : blocked resistance Ron : resistance in conduction  |
                         Diode  |
                     Exponential functions |
                         Is : saturation current Rs : series resistance Ut : voltage of the temperature  |
                         Is : saturation current Rb : extrinsic resistance VF0 : bend tension  |
Associated command signals
The switch need a signal to command them. The table below presents the different possibilities of commands.
| Proposed commands and their characteristics | ||
                         At start  |
                     By formula | |
| By square signal |
                         Pulse start End of pulse Period of signal  |
