Isotropic / anisotropic materials
Introduction
The studied materials can be isotropic or anisotropic. In other words, the thermal conductivity is:
independent of the direction of the applied temperature gradient (isotropic material)
dependent on the direction of the applied temperature gradient (anisotropic material)
These two cases are presented in the following sections.
Isotropic materials
Isotropic materials are characterized by a thermal conductivity, which is independent of the direction of the applied temperature gradient.
The
 and
 vectors
are always collinear.
The dependence between
 and
 is a
scalar relationship,
 which is written as:
Anisotropic materials
Anisotropic materials are characterized by a thermal conductivity, which is dependent on the direction of the applied temperature gradient.
The
 and
 vectors
are not collinear.
 and
 is a
vector relationship,
with k conductivity tensor:
… in Flux
The model provided in Flux is a simplified model.
The vector dependence between
 and
can therefore be expressed in the form of three curves:
The conductivity tensor is written:
