Entity selection: Circumstances and selection modes
Introduction
The most part of actions for handling the entities require the selection of entities .
Indeed:
- to modify the coordinates of a point, you should select the corresponding point
 - to add a line (segment), you should define extremity points and then select starting point and ending point
The different selection circumstances and selection modes are presented in this paragraph.
Selection circumstances: overview
Selection of entities could be done before or after the activation of a command; it could also be done, during an operation of creation.
These various circumstances of selection are presented through examples in the table below.
| Selection before activation of a command | |
                         … Activation of a command:
| Selection after activation of a command (via selection box) | |
| Selection during an operation of creation | |
Selection modes: overview
Selection of entities could be done with the following different selection modes:
- graphic selection (directly with the mouse)
- in the data tree for all entities
 - in the graphic area for graphic entities
- identifier selection (by name / by number )
 - criterion selection* (by relation / by … identical characteristics )
* the advanced selection is detailed in § Entity selection: Selection by criterion
Summary
The different selection modes proposed function of selection circumstances are gathered in the table below.
| Selection circumstances | … | Selection modes |
                     graphic | |
                         Selection after activation of a command  |
                     Selection box |
                         graphic by identifier (name/number) by criterion  |
                     Specialized box |
                         graphic by identifier (name/number)  |
