Once the topology optimization is completed, Flux 2D will write the following outputs
                in the
Working directory configured by the user:
                    - A new Flux 2D project containing the optimized design. This project has the
                        following properties:
                            - This project may or may not be automatically opened in a new
                                instance of Flux 2D at the end of the optimization, depending on the
                                settings configured in the Optimization options (as discussed
                                in step 7 of the previous section).
                            - The new project has its name derived from the name of the initial
                                project (the string _OptimizationResults is appended to the
                                original project name).
                            - That project contains the design that results from the topology
                                optimization, considering the default Density threshold
                                configured in the Optimization options (see step 7 of the
                                previous section).
Note: In the topology
                                    optimization procedure, the material density is a real-valued
                                    function in the range [0,1] defined on the faces subjected to
                                    optimization. The Density threshold is the lowest density
                                    value for which the material is considered present in a given
                                    design.
Note: To make sure that the
                                    design resulting from the topology optimization is properly
                                    displayed in the new Flux project, it is mandatory to click the
                                    button Display or hide face elements available in the
                                    Flux 2D toolbar after its opening.
                            - The scenario provided for the execution of the command Run
                                    Topology optimizaton is solved in the new project.
                                Consequently, it is ready for post-processing, allowing the user to
                                evaluate electromagnetic quantities to verify if the optimization
                                goals and constraints have been satisfied.
                    - An H3d file (with .h3d extension) representing the evolution of the
                        optimized design through the optimization procedure. This file may be opened
                        in Altair SimLab and has the following properties:
                            - Its name is derived from the name of the initial project used to
                                launch the topology optimization (the string _des is appended
                                to the original project name).
                            - It may be used to display in SimLab a graphical representation of
                                the design at each optimization step. More precisely, it allows
                                viewing a color map representing the material density function on
                                the faces subjected to optimization at each optimization step.
                            - It may also be used to explore the effect of changing the material
                                    Density threshold at each optimization step, including
                                the final design. This may be achieved with the aid of Shape
                                    Explorer tool available in SimLab. Analyzing the results
                                this way is useful to explore the impact of that threshold in the
                                final design yielded by the optimization.
                            - The H3d file may be previewed and analyzed in SimLab during the
                                optimization process, before it reaches its end.
            The
Density threshold may also be modified in the project containing the
                topology optimization results to generate variations of the final design. To modify
                this threshold and generate a new project with a variant design:
                    - In the project with the topology optimization results, click the
                            Solving menu.
                    - Select the command Explore topologies from optimization results.
                    - In the Explore topologies from optimization results dialog box:
                            - Provide a name for the new project (the project is overwritten with
                                the new design if no name is provided)
                            - Provide the new value for the density threshold in the field.
                    - After confirming the threshold modification, Flux will update the design.
Note: After updating the design with a new density
                            threshold, the user needs to re-solve the scenario to
                            post-process the results.
