getOhcVarUnit()
Return the HC unit (default unit of unit category) of adb variable.
Usage
ohcVarUnit = adb.getOhcVarUnit( name )
name (integer) or (string)
Name or ID of an OHC name.
Return Value
ohcVarUnit (list) or (string)
The HC unit (default unit of unit category) of adb variable.
This routine returns the HC unit (default unit of unit category) of adb variable. This function needs an index as argument which is given by name. For example,
ohcVarUnit = adb.getOhcVarUnit( "wall" )
