getResRatioTimes()
Return the "Residual Ratio" times value.
Usage
resRatioTimes = adb.getResRatioTimes( var, type = 'all' )
- var (string) or (integer)
- The "Residual Ratio" variable name/index.
- type (string)
- The type value; 'all', 'initial' and 'final'.
Return Value
- resRatioTimes (numarray)
- The "Residual Ratio" time values.
var must be a valid name or index.
type must be 'all', 'initial' or 'final'.
resRatioTimes = adb.getResRatioTimes( 'velocity' )
