nanoFluidX
nanoFluidX
2023.1
  1. Home
  2. Run nanoFluidX
    How to run a nanoFluidX model.
  3. Launch a Simulation
    Launch a simulation via a Linux or Windows terminal, or via PBS access.
  • What's New
  • Overview
  • Video Tutorials
  • Pre-processing with SimLab
  • Run nanoFluidX
  • Post-processing with ParaView
  • Simulation Guidance
  • Command Reference
  • Theory Manual
  • Validation Cases
  • Performance Benchmarks
  • Error and Warning Messages
  • Frequently Asked Questions
  • Bibliography
Index
nanoFluidX
2023.1
nanoFluidX
  • What's New
    View new features for nanoFluidX 2023.1.
  • Overview
    nanoFluidX is a software to simulate single and multi-phase flows based on the Lagrangian Particle Method Smoothed Particle Hydrodynamics (SPH).
  • Video Tutorials
    Discover nanoFluidX functionality with interactive tutorials.
    Create a nanoFluidX model using SimLab.
  • Run nanoFluidX
    • Platform and Hardware Requirements
      Platforms, operating systems, and processors supported by nanoFluidX and recommended and required hardware.
    • Basic Usage
      Sample configuration files and geometry input files are provided with the binary to test the proper system setting and see if the simulation starts correctly on the system.
    • Launch a Simulation
      • Launch a Simulation via Linux Terminal
      • Launch a Simulation via Windows Terminal
      • Launch a Simulation via PBS Access
    • Multi-node Jobs
      Recommendations for running multi-node jobs.
    • nanoFluidX Prep
      nanoFluidX prep, shortened as nFX[p], is an auxiliary executable for nanoFluidX intended to eliminate a number of potential user errors during the pre-processing phase.
    • nanoFluidX Companion
      nanoFluidX companion, also known as nFX[c], is a post-processing tool developed to accompany the nanoFluidX solver allowing for an easier execution of certain post-processing tasks.
    • nanoFluidX Monitor
      nanoFluidX monitor, known as nFX[m], is a single file portable Python executable that is aimed for helping with monitoring a nanoFluidX simulation during runtime.
    • Restart a Simulation
    • Troubleshoot a Simulation
      How to troubleshoot a simulation which fails to run or stops prematurely.
    How to post-process nanoFluidX results using ParaView.
    Guidance on modeling specific usecases with nanoFluidX.
  • Command Reference
    nanoFluidX commands and parameters with examples.
  • Theory Manual
    Physics and theory for nanoFluidX.
  • Validation Cases
    Validation cases for the dynamic testing of nanoFluidX.
    Performance benchmark results for nanoFluidX.
    This glossary contains generic messages generated by nanoFluidX, their likely causes, and possible methods to resolve the related issues.
    This section provides quick responses to typical and frequently asked questions regarding nanoFluidX.
  • Bibliography
    References used throughout the nanoFluidX manual.
nanoFluidX
nanoFluidX
2023.1
  1. Home
  2. Run nanoFluidX
  • What's New
  • Overview
  • Video Tutorials
  • Run nanoFluidX
  • Command Reference
  • Theory Manual
  • Validation Cases
  • Bibliography
Index
Launch a Simulation
