Command Reference
nanoFluidX commands and parameters with examples.
nanoFluidX uses two files to setup a simulation. A configuration file, which defines all relevant simulation parameters and phase properties, and a geometry file, that defines the initial discretization of the problem with particles.
Configuration File (.cfg)
- Vector components are placed in quotation marks.
 - It is recommended that all input files (.prtl and .cfg) are in ASCII format.
 - All names in the .cfg file and file names outside (in the case of working folders), should be alphanumeric ASCII. The only exceptions are the .stl geometry file names.
Particle File (.prtl)
The particle file (*.prtl) defines the particles used in the simulation and their phase assignment.
1 0.0 0.0 0.0
                    1 0.0 0.0 0.1
                    1 0.0 0.1 0.0
                    2 0.0 0.2 0.0
                    …The geometry file can also contain an initial velocity (for FLUID phase type) or wall
                velocity field (for WALL phase type). This alternative format is enabled by using
                the inputfileReadMode command in the Domain Parameters section.
                When set to INPTFL_PXYZUVW, the required geometry file must have
                three columns for velocity components in the X, Y, and Z direction.
Simple geometries are defined manually or via script. For industrial cases using complex geometries, the SimLab pre-processor is used to generate the initial geometry files. More information on using SimLab can be found in the SimLab tutorials or during a nanoFluidX training.
