Riemann Particle Interaction Scheme
The Riemann problem can be defined as a category of initial value problems that involve a conservation equation and a piecewise data set with a single discontinuity.
Where, the avg index denotes the mean value of the respective value between the two particles.
Where, v∗=U∗eij+(vavg−ij−Uavgeij) .
- INSTANT
- The instant density filtering is basically a 0th-order Shepard filter.
At each evaluation point (according to the number set by
RM_freq_rho_init), the density is re-calculated
by:
(5) Where,ρi=∑jmjWij∑jVjWij- ρi
- Density of particle I
- mj
- Mass of particle j
- Vj
- Volume of particle j
- Wij
- Weight calculated from the kernel function
- INCREMENTAL
- A modified 1st-order density filtering scheme is used as an additional
option. The operator is calculated following:
(6) Where, ρi is the density from solving the continuity equation before applying the filter.ρi=∑jmjWijmin(1,∑jmjρ∗Wij)
