Meshing
BatchMesher supports creation of feature entities and saves to the output .hm file. These can then be visualized and edited through the Feature Manager.
New Features
- Meshing Release Highlights
- Watch this video to learn more about Meshing features in 2023.
- Normals Context
- New context workflow is available to reverse and adjust the normals of surfaces and shell elements.
- Split Context
- New context workflow is added to migrate the following panels:
- Element Split is now Plate Split
- Solid Split
- Layer Split
- Combine
Enhancements
- Rebuild
- Performance improvements.
- Midmesh
- Automatic extraction performance improvements for extruded parts.
- Mesh Edit Workflow
- This workflow is now migrated to Imprint context under the 2D ribbon.
- Hex Tool
- Added support for mixed guides selections.
- FE Geometry
- A new Coupled Show/Hide/Isolate mode has been added to bring the
Associated Element/Surface to the selected entity.
- This allows for the "classic" FE Geometry mode.
- Extends to both CAD Geometry and FE Geometry.
