Decimate Mesh
Use the Decimate tool to coarsen mesh based on a defined element size.
                From the Discrete ribbon, click the Decimate tool.
- Select surfaces or parts to consider.
                Enter a size threshold.
                Any input elements that have edge lengths smaller than this size value are decimated.
                Enter a feature angle constraint.
                Any input elements that have a defined angle less than this value are decimated. For inputs with higher curvature, define a higher angle to loosen the constraint.
                Click Decimate.
 Figure 2. Input
 Figure 3. Result with decimation size 100 and angle 1
 Figure 4. Result with decimation size 100 and angle 10
