Use the Repair tool to find, review, and fix issues in the mesh.
        Before you begin, add surface mesh to the model.Note: This tool only works on visible surfaces. For better
                visibility, first isolate surfaces with mesh issues then use this tool. To do that,
                go to the Mesh ribbon, set the entity selector to
                    Surfaces, then right-click and go to  and select the required mesh check option.
