Fan
Assign a part as a fan component.
fan = vwt.Fan(partId)
partId
Part or list of parts
Attributes
axis
Axis of rotation
center
Wheel center
speed
Rotational speed
diameter
Diameter of cylindrical volume
length
Length of cylindrical volume
offset
Offset distance of solid revolution from fan parts
refinementLevel
Mesh refinement level of rotating volume
interfaceRefinement
Enable interface refinement for Overset volume
interfaceRefinementLevel
Interface refinement level
Methods
rotatingVolume(type, partId)
Assign part as an MRF or Overset volume
rotatingCylinder(type)
Create a cylinder as MRF or Overset volume
solidRevolution(type)
Create a solid revolution around fan as MRF or Overset volume
splitParts()
Split intersecting fan parts with rotating volume
