Heat Exchanger
Create a heat exchanger component.
hx = vwt.HeatExchanger()Methods
- setInlets(partId)
- Assign part as an Inlet for the heat exchanger
- setOutlets(partId)
- Assign part as an Outlet for the heat exchanger
- setWalls(partId)
- Assign part as a Wall of the heat exchanger
Attributes
- inertialCoefficient
- Inertial porous media coefficient to model the heat exchanger
- viscousCoefficient
- Viscous porous media coefficient to model the heat exchanger
- permeabilityDirection
- Permeability direction - vector type
