Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Use the Extension Manager to register, view currently registered, and
load/unload/remove extensions.
Restriction: Ribbon, menus, and toolbars are hidden when an extension is
unloaded. To perform a complete internal cleanup, you must restart. The newly
introduced customized file menus are not unloaded in 2022.2.
From the menu bar, click File
and select Extensions from the file menu.
The Extension Manager dialog opens.
In the Extension Manager dialog, register and load an
extension.
Click Add Extension.
Browse and select the directory with the desired extension.
Important: The directory must contain the
extension.xml file which defines the
structure of the extension.
To load the extension, enable the slider.
Figure 1. Extension Manager with Loaded Extensions
To unload an extension, disable the slider in the Extension
Manager dialog.
To unregister an extension, select the desired extension and click
Remove in the Extension Manager
dialog.
Select the desired extension to see the Extension detailed view containing more
information about the extension.
The detailed view shows the location of the Extension and provides access to
additional help in the Description area, if the extension provides it:
Figure 2. Extension Detailed View
Optional: To start with a pre-defined set of extensions, set the environment variable
HWX_PLUGINS to add one or more directories separated
by a comma.
The Remove button for those directories is disabled.
Figure 3.
Disable the Remove button by using the removable keyword in the general section
of the extensions.xml file.
