How you use HyperStudy depends on your model type, your simulation software and your design objectives among other factors. You can use
HyperStudy as a standalone software or you can start it from another product.
Once you have finished setting up your study, you will need to select one or more study approaches to find the answers
to your study questions. The best combination of approaches and the best method to use for each approach depends on
your application and objectives.
Common Use Cases for Setting Up a Study
How you use HyperStudy depends on your model type, your simulation software and your design objectives among other factors. You can use HyperStudy as a standalone software or you can start it from another product.
Common Use Cases for Selecting Approaches
Once you have finished setting up your study, you will need to select one or more study approaches to find the answers to your study questions. The best combination of approaches and the best method to use for each approach depends on your application and objectives.
