What's New
View new features for HyperStudy 2023.1.
Altair HyperStudy 2023.1 Release Notes
New Features
- Quantification of complex relationships between inputs and outputs
- Global variance-based sensitivity method, based on Total Sobol Indices.
- Integration of physicsAI models
- physicsAI models can now be deployed inside HyperStudy.
- Alternative graphical user interface
- As well as the classic interface, a new ribbon style interface is now available.
Enhancements
- 3D visualization of CAE models and results
- Visual post-processing of simulation models and results is now supported via Media Sources.
- Auto-selecting best fit model for vector predictions
- FAST algorithm has been extended to support vector fits.
- Optimization with vector responses
- Optimization goals can be defined directly on Data Sources.
- Terminating processes in different ways
- The stop command in the Evaluate step now supports options on how to terminate a process.
- Flexibility in finding files to purge
- Purge tool now supports wildcard-based search and selecting files through the browser.
- Auto-handling of hanging subprocesses
- A timeout option has been added in Evaluation Parameters to terminate zombie child processes.
Resolved Issues
- Numerical discrepancies in Tutorial HS-1610.
- Undo action did not work for removed models.
Announcements
- Availability of Xopt will be deprecated in version 2024.0.
Altair HyperStudy 2023 Release Notes
New Features
- Explore Historical Data
- A new model type has been introduced to process output files of existing data in a chosen directory. All the files containing historical data are automatically distributed to their respective run directories.
Enhancements
- Measures as Output Variable
- HyperView connection now supports measure type responses.
- Launching Processes with Select Environment Variables
- Environment variables can now be independently set and unset for each solver process.
- Performance Gain in Model Evaluations
- HyperStudy Fit and Internal Math Models can now be optionally run without directories to improve performance.
- User Macros in Excel Connection
- A new model setting option has been added to specify the macro.
- Auto-Selecting Best Fit Model for Vector Predictions
- FAST algorithm has been extended to support Vector Fits.
Announcements
- Classic HyperMesh and MotionView connections have been retired.
