ardi.format
ardi.format.layout
Query layout information. This is valid only for report in Presentation format. Layout information originates from the Ms-office master document.
ardi.format.layout.exists
- Syntax
- ardi.format.layout.exists
- Parameters
                            - -name (mandatory)
- Value: Name of the layout.
- Returns
- Boolean
- Example
- ardi.format.layout.exists(name="One Table")
ardi.format.layout.getlist
- Syntax
- ardi.format.layout.getlist
- Returns
- The list of layout names.
ardi.format.layout.getmasterlayouts
- Syntax
- ardi.format.layout.getmasterlayouts
- Parameters
- None
- Returns
- The item ID's of master slide layouts.
ardi.format.layout.getslidelayouts
- Syntax
- ardi.format.layout.getslidelayouts
- Parameters
- None
- Returns
- The item ID's of slide layouts example.
