ardi.item
Report Item: access/modify Report Items.
ardi.item.chapter
Interact with items of type chapter. This item type is valid only for document reports.
Supported property names are:-name-value-parent-type (read only).
All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi.item.chapter.create
Creates an item of type "chapter".
- Syntax
- ardi.item.chapter.create
- Parameters
                        - For
- Value: A full list of property names see "Supported property names" above.
- Returns
- The ID of the item or Python-error in case an error occurred during creation.
- Example
- ardi.item.chapter.create -name "My Chapter Item"
ardi.item.chapter.delete
Deletes the item with the specified ID.
- Syntax
- ardi.item.chapter.delete
- Parameters
                        - -id
- Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
- Returns
- 1 for OK, Python-error in case of error.
- Example
- ardi.item.chapter.delete -id $id
ardi.item.chapter.get
Queries the value of one property.
- Syntax
- ardi.item.chapter.get
- Parameters
                        - -id
 - For
- Returns
- The value of the specified property or Python-error in case of error.
- Example
- ardi.item.chapter.get -id $id -property parent
ardi.item.chapter.set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
- Syntax
- ardi.item.chapter.set
- Parameters
                        - -id
- Mandatory Value: Item ID. The item ID which is returned by the corresponding "create" API.
 - For
- Returns
- Example
- ardi.item.chapter.set -id $id -name "My Chapter Item" -value "Good monring, how are you today?"
ardi.item.chapter.hasproperty
Check if the item has property with specified key.
- Syntax
- ardi.item.chapter.hasproperty
- Parameters
                        - -id
- Value: Item ID.
 - -key
- Value: Property key.
- Returns
- 1 if valid, 0 if invalid.
ardi.item.exceldocument
Interact with items of type exceldocument.
Supported property names are:-name-value-parent-type (read only)-file-sheet-caption-capitalisation.
ardi.item.exceldocument.create
Creates an item of type "exceldocument".
- Syntax
- ardi.item.exceldocument.create
- Parameters
                        - For
- Returns
- Example
- ardi.item.exceldocument.create -name "My External Excel Document Item"
ardi.item.exceldocument.delete
- Syntax
- ardi.item.exceldocument.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.exceldocument.delete -id $id
ardi.item.exceldocument.get
- Syntax
- ardi.item.exceldocument.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.exceldocument.get -id $id -property parent
ardi.item.exceldocument.getcell
Queries the value of one property from table cell.
- Syntax
- ardi.item.exceldocument.getcell
- Parameters
                        - -id
 - -row
- Mandatory value: Row ID. Row ID is an integer starting from 0.
 - -column
- Mandatory value: Column ID. Column ID is an integer starting from 0.
 - -property
- Mandatory value: Property name. 'value' or 'href'
- Returns
- Example
- ardi.item.exceldocument.getcell -id $id -row 0 -column 0 -property values
ardi.item.exceldocument.getpropertyid
Queries id of property.
- Syntax
- ardi.item.exceldocument.getpropertyid
- Parameters
                        - -id
- Value: Item ID.
 - -key
ardi.item.exceldocument.getpropertykeylist
Queries list of properties.
- Syntax
- ardi.item.exceldocument.getpropertykeylist
- Parameters
                        - -id
 - -row
- Value: Item ID.
- Returns
- List of property keys for a particular item ID.
ardi.item.exceldocument.set
- Syntax
- ardi.item.exceldocument.set
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.exceldocument.set -id $id -name "My External Excel Document" -file "c:/temp/mydoc.xlsx"
ardi.item.exceldocument.setcell
Sets one or multiple parameters to table cell.
- Syntax
- ardi.item.exceldocument.setcell
- Parameters
                        - -id
 - -row
 - -column
 - -value
- Value: The value you want to set on the cell.
 - -href
- Value: Object ID to hyperlink.
- Returns
- Example
- ardi.item.exceldocument.setcell -id $id -row 0 -column 0 -value "Hello" -href $refobjid
ardi.item.image
Interact with items of type image.
Supported property names are:-name-value-parent-type (read only)-config-hwpage-hwwindow.
ardi.item.image.create
Creates an item of type "image".
- Syntax
- ardi.item.image.create
- Parameters
                        - For
- Returns
- Example
- ardi.item.image.create -name "My Image Item"
ardi.item.image.delete
- Syntax
- ardi.item.image.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.image.delete -id $id
ardi.item.image.get
- Syntax
- ardi.item.image.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.image.get -id $id -property parent
ardi.item.image.set
- Syntax
- ardi.item.image.set
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.image.set -id $id -name "My Image Item" -value "Good monring, how are you today?"
ardi.item.module
ardi.item.module.create
Creates an item of type "module".
- Syntax
- ardi.item.module.create
ardi.item.module.delete
- Syntax
- ardi.item.module.delete
- Parameters
                        - -id
- Returns
ardi.item.module.get
Gets property value of an Item.
- Syntax
- ardi.item.module.get
ardi.item.module.set
Sets property value of an Item.
- Syntax
- ardi.item.module.set
ardi.item.pagebreak
ardi.item.pagebreak.create
Creates an item of type "break".
- Syntax
- ardi.item.pagebreak.create
- Parameters
                        - For
- Returns
- Example
- ardi.item.pagebreak.create -name "My Image Item"
ardi.item.pagebreak.delete
- Syntax
- ardi.item.pagebreak.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.pagebreak.delete -id $id
ardi.item.pagebreak.get
- Syntax
- ardi.item.pagebreak.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.pagebreak.get -id $id -property parent
ardi.item.pagebreak.set
- Syntax
- ardi.item.pagebreak.set
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.pagebreak.set -id $id -name "My Image Item" -value "Good monring, how are you today?"
ardi.item.property
ardi.item.property.create
Creates an item of type "property".
- Syntax
- ardi.item.property.create
- Parameters
                        - -id
- Mandatory value: Parent item ID of type text, image, table, module\parent.
 - -key
- Mandatory value: Unique key/name for the property.
 - -name
- Value: "Display name of the property, if not specified key is used as display name".
 - -type
- (defaults to str): Type of property.
 - For
- Returns
- Example
- ardi.item.property.create -id $parentid -key "MyKey" -name "My Property" -value "My Value" -type "str"
ardi.item.property.delete
- Syntax
- ardi.item.property.delete
- Parameters
                        - -id
- Mandatory value: Parent item ID of type text,image,table,module etc, \parem
 - -name
- Mandatory value: Name of the property.
- Returns
- Example
- ardi.item.property.delete -id $id
ardi.item.property.get
- Syntax
- ardi.item.property.get
- Parameters
                        - -id
 - For
 - -column
 - -property
- Returns
- Example
- ardi.item.property.get -id $id -property parent
ardi.item.property.set
Sets name and value of specific property.
- Syntax
- ardi.item.property.set
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.property.set(id=itemid,value="Test")
ardi.item.slide
ardi.item.slide.create
Creates an item of type "slide".
- Syntax
- ardi.item.slide.create
- Parameters
                        - For
- Returns
- Example
- ardi.item.slide.create -name "My Slide Item"
ardi.item.slide.delete
- Syntax
- ardi.item.slide.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.slide.delete(id=itemid)
ardi.item.slide.get
- Syntax
- ardi.item.slide.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.slide.get -id $id -property parent
ardi::item::slide set
- Syntax
- ardi::item::slide set
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.slide.set(id=itemid,name="My Slide Item",value="Good monring, how are you today?")
ardi.item.table.
Interact with items of type table.
Supported property names are:-name-value-parent-type (read only)-numberless-numberofcolumns -showcolumnheader-showrowheader.
ardi.item.table.create
Creates an item of type "table".
- Syntax
- ardi.item.table.create
- Parameters
                        - For
- Returns
- Example
- ardi.item.table.create -name "My Table Item"
ardi.item.table.delete
- Syntax
- ardi.item.table.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.table.delete -id $id
ardi.item.table.get
- Syntax
- ardi.item.table.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.table.get -id $id -property parent
ardi.item.table.getcell
Queries the value on a cell identified by row and column ID. Row and column IDs start with 0.
- Syntax
- ardi.item.table.getcell
- Parameters
                        - -id
 - -row
- Mandatory value: Row ID. The ID of the row.
 - -column
- Mandatory value: Column ID. The ID of the column.
 - -property
- Mandatory value: 'value', 'href', 'color', 'textcolor', 'fontname', 'fontstyle', 'horizontal_alignment' and 'vertical_alignment'.
- Returns
- The value of the cell, Python-error in case of error.
- Example
- ardi.item.table.getcell(id=itemid,row=0,column=0)
ardi.item.table.getheader
Queries the header text on a row or on a column. Row and column IDs start with 1. Specify either row or column ID to query the current value.
- Syntax
- ardi.item.table.getheader
- Parameters
                        - -id
 - -row
- Value: Row ID. The ID of the row you want to query the header text.
 - -column
- Value: Column ID. The ID of the column you want to query the header text.
- Returns
- The header text, Python-error in case of error.
- Example
- ardi.item.table.getheader -id $id -column 1
ardi.item.table.set
- Syntax
- ardi.item.table.set
- Parameters
                        - -id
 - For
 - -column
- Returns
- Example
- ardi.item.table.set -id $id -name "My Table Item" -value "Good monring, how are you today?"
ardi.item.table.setcell
Sets the value on a cell identified by row and column ID. Row and column IDs start with 0.
- Syntax
- ardi.item.table.setcell
- Parameters
                        - -id
 - -row
 - -column
 - -value
 - -href
- Value: Object ID to set cross-reference to.
- Returns
- Example
- ardi.item.table.setcell -id $id -column 1 -value "My Header Text on column 1"
ardi.item.table.setheader
Sets the header text on a row or on a column. Row and column IDs start with 0. Specify either row or column ID to set the header text to desired value.
- Syntax
- ardi.item.table.setheader
- Parameters
                        - -id
 - -row
- Value: Row ID. The ID of the row you want to set a particular header text.
 - -column
- Value: Column ID. The ID of the column you want to set a particular header text.
 - -value
- Value: The text you want to set as header of the specified row or column ID.
- Returns
- Example
- ardi.item.table.setheader(id=itemid,column=1,value="My Header Text on column 1") i.e ardi.item.table.setheader(id=itemid,row=2,value="My Row Header")
ardi.item.tableofreference
Interact with items of type tableofreference.
Supported property names are: -name-value-parent.
All properties available can be passed via the "create" API or modified on an existing item via the "set" API. After creation all the properties that applies for table type can be used.
ardi.item.tableofreference.create
Creates an item of type "tableofreference".
- Syntax
- ardi.item.tableofreference.create
- Parameters
                        - For
- Returns
- The ID of the item type table or Python-error in case an error occurred during creation.
ardi.item.tableofreference.delete
- Syntax
- ardi.item.tableofreference.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.tableofreference.delete(id=itemid)
ardi.item.tableofreference.get
- Syntax
- ardi.item.tableofreference.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.tableofreference.get(id=itemid,property='parent')
ardi.item.tableofreference.set
- Syntax
- ardi.item.tableofreference.set
- Parameters
                        - -id
 - For
- Returns
- 1 for OK, python-error in case of error.
- Example
- ardi.item.tableofreference.set(id=itemid,name="My Table of References" -parent $parentid"
ardi.item.text
Interact with items of type text.
ardi.item.text.create
Creates an item of type "text".
- Syntax
- ardi.item.text.create
- Parameters
                        - For
- Returns
- Example
- ardi.item.text.create(name="Text1",value="My Text Content")
ardi.item.text.delete
- Syntax
- ardi.item.text.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.text delete(id=itemid)
ardi.item.text.get
- Syntax
- ardi.item.text.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.text.get(id=itemid,property='parent')
ardi.item.text.getcrossref
Queries the cross reference within text item.
- Syntax
- ardi.item.text.getcrossref
- Parameters
                        - -id
ardi.item.text.set
- Syntax
- ardi.item.text.set
- Parameters
                        - -id
 - For
- Returns
- 1 for OK, -Python-error in case of error.
- Example
- ardi.item.text.set(id=itemid,name="My Text Item",value="Good monring, how are you today?")
ardi.item.text.setcrossref
Sets the cross reference within text item.
- Syntax
- ardi.item.text.setcrossref
ardi.item.textdocument
Interact with items of type textdocument.
Supported property names are:-name-file-parent.
ardi.item.textdocument.create
Creates an item of type "textdocument".
- Syntax
- ardi.item.textdocument.create
- Parameters
                        - For
- Returns
- Example
- ardi.item.textdocument.create(name="My Text File",file="example.txt")
ardi.item.textdocument.delete
- Syntax
- ardi.item.textdocument.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.textdocument.delete(id=itemid)
ardi.item.textdocument.get
- Syntax
- ardi.item.textdocument.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.textdocument.get(id=itemid,property='parent')
ardi::item::textdocument.set
- Syntax
- ardi::item::textdocument.set
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.textdocument.set(id=itemid,name="My External Excel Document",file= "c:/temp/textdocument.txt")
ardi.item.worddocument
Interact with items of type worddocument.
ardi.item.worddocument.create
Creates an item of type "worddocument".
- Syntax
- ardi.item.worddocument.create
- Parameters
                        - For
- Returns
- The ID of the item or python-error in case an error occurred during creation.
- Example
- ardi.item.worddocument.create(name="My Word Document",file="example.docx")
ardi.item.worddocument.delete
- Syntax
- ardi.item.worddocument.delete
- Parameters
                        - -id
- Returns
- Example
- ardi.item.worddocument.delete(id=itemid)
ardi.item.worddocument.get
- Syntax
- ardi.item.worddocument.get
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.worddocument.get(id=itemid,property='parent')
ardi.item.worddocument.set
- Syntax
- ardi.item.worddocument.set
- Parameters
                        - -id
 - For
- Returns
- Example
- ardi.item.worddocument.set(id=itemid,name="My External Word Document",file ="c:/temp/example.docx"
ardi.item.apply
For better performance data created, manipulated or deleted go into a cache.
- Syntax
- ardi.item.apply
- Parameters
                        - -name
- Value: Layout name to use in case of presentation.
 - -itemlist
- Value: List of item ids to apply.
 - -parent
- Value: parent of the cached items. If not specified root item will act as a parent. This API processes the cached data, clears the cache and redraws the GUI if needed.
 - -property
- Mandatory value: Property name. 'value' or 'href'.
- Returns
ardi.item.delete
- Syntax
- ardi.item.delete
- Parameters
                        - -id
- Value: Item ID.
- Returns
ardi.item.get
Queries the value of one property or role or attribute.
- Syntax
- ardi.item.get
- Parameters
                        - -id
 - For
- Returns
- The value of the specified property/role/attribute or python-error in case of error.
- Example
- ardi.item.get -id $id -property parent
ardi.item.getpropertyid
Queries ID of property.
- Syntax
- ardi.item.getpropertyid
- Parameters
                        - -id
- Value: Item ID.
ardi.item.getpropertykeylist
- Syntax
- ardi.item.getpropertykeylist
- Parameters
                        - -id
- Value: Item ID.
- Returns
ardi.item.getslidelayouts
Queries slide based layouts.
- Syntax
- ardi.item.getslidelayouts
- Returns
- The list of slide layout IDs.
ardi.item.getmasterlayouts
Queries master layouts.
- Syntax
- rdi.item.getmasterlayouts
- Returns
- The list of master layout ID's.
ardi.item.gettype
Queries the type of the item with the specified ID.
- Syntax
- ardi.item.gettype
- Parameters
                        - -id
- Value: Item ID.
- Returns
- The type of the item.
ardi.item.gettypelist
Queries available types of items.
- Syntax
- ardi.item.gettypelist
- Returns
- A list of item types.
ardi.item.hasproperty
- Syntax
- ardi.item.hasproperty
- Parameters
                        - -id
- Value: Item ID.
 - -key
- Returns
ardi.item.isvalid
Check if the item with the specified ID is valid.
- Syntax
- ardi.item.isvalid
- Parameters
                        - -id
- Value: Item ID.
- Returns
ardi.item.set
- Syntax
- ardi.item.set
- Parameters
                        - -id
 - For
- Value: A full list of standard property names see "Supported property names" above. Use rpti::item getpropertykeylist for list of dynamic properties.
- Returns
- Example
- ardi.item.set -id $id -name "My Text Item" -value "Good monring, how are you today?"
