::ShowEntryUnselected
This command deselects an mdl3StateEntry widget.
::model::mdl3StateEntry::SetEntryUnselected path
MotionView Tcl GUI
- path
- The full path to the mdl3StateEntry of interest. The path argument is the return value of the model::mdl3StateEntry procedure used to create an mdl3StateEntry.
model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entPnt Point p_0 "\"Point 0\""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set lbl [ label $dlg.frm.lbl -text "X" -width 3 -anchor w ]
grid $lbl -row 0 -column 0 -sticky nws
set stEntry  [model::mdl3StateEntry .dlg.frm.stEntry entPnt "x" ]
grid $stEntry  -row 0 -column 1
model::mdl3StateEntry::ShowEntrySelected   $stEntry
model::mdl3StateEntry::ShowEntryUnselected $stEntry
entPnt ReleaseHandleErrors
Returns true if it is successful and false if unsuccessful.
