hwIMessageLog AddMessage
Adds a message to the Message Log.
hwIMessageLog_handle AddMessage messageType message
Tcl Modify
This command adds a message to the Message Log.
- messageType
- The type of message that you want to add. The different types include (with numbers
            being the user input): - 0
- Warning
- 1
- Error
- 2
- Info
- 3
- Line
- 4
- Header
- 5
- Footer
- 6
- YesNo
- 7
- YesNoInfo
- 8
- YesNoWithAll
- message
- The message that the you want to put in the Message Log.
hwi GetSessionHandle sess;
sess GetMessageLogHandle msglog;
msglog AddMessage 0 "There is something not right.";Error
Keywords
Tcl
Message Log
Modify
