hwIMessageLog SetMessageLimit
Changes the maximum number of messages that can be stored in the Message Log.
hwIMessageLog_handle SetMessageLimit messageLimit
Tcl Query
This command sets the maximum number of messages that can be stored in the Message Log.
- messageLimit
- An integer value specifying the maximum number of messages that can be stored in the
            message log. - If the new limit is less than the current limit, then the oldest messages in the log will be lost.
- If the new limit is greater than the current limit, there is no effect on the contents of the log.
hwi GetSessionHandle sess;
sess GetMessageLogHandle msgLog;
msgLog SetMessageLimit 2048Error
Keywords
Tcl
Message Log
Modify
