hwIProject CopyPage
Copies a page.
hwIProject_handle CopyPage page, append
Tcl Modify
This command copies a page in the project based on the page number you input.
- page
- The page number that you want to copy.
- append
- true or false. - true
- Indicates the copy is added to a memory.
- false
- Indicates that the copy is not added to memory.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj CopyPage 1 falseError
Keywords
Tcl
Modify
